TX7 Android 7.1 Amlogic S905X Quad Core 2/32gb Dual Band WiFi 2.4GHz/5GHz BT4.0
All Metal Case, External Antenna, spec looking good S905x 2/32GB etc.
Let's see what surprises can be found.
The Box
What's in the box
Look Around
Remove Base, Could add some thermal Pad Between base and PCB if need
Remove PCB
The Main Bits
looking ok so far, appears well mad and solid
For more Discussion and review on the Tanix TX7
Click Here >>> http://freaktab.com/forum/tv-player-...467#post705467
Gearbest
