C6 Mini Projector 905X 2/16GB Dual WiFi BT4 DLP 0.3 inch DMD + RGB LED
    C6 Mini DLP Projector
    Mini C6 DLP projector is small size and portable. Super mini design, away from the dull appearance image. It will give you infinite pleasure from large display anytime and anywhere.
    The device runs on the Android 5.1, the OS may sound outdated but it is more than enough for a device as a projector. Using the DLP technology to ensure stable images and bright. Digital light processor ( DLP ) is a general trend in supervising and controlling system.
    Main Features:
    ● Adopt DLP technology to achieve high fidelity image and a clear bright vivid picture.
    ● Only 50dB, low noise.
    ● Lifespan up to 20000 hours.
    ● Built-in dual-band WiFi ( 2.4GHz + 5GHz ) makes the signal stronger and more stable, and Bluetooth 4.0 gives you ultra-low latency, distance farther, faster share.
    ● Wireless connect with iPhone, iPad, laptop with WiFi, free your hand.
    ● Built-in 4000mAh lithium-polymer battery.
    Gearbest
    Today we can have a Close look at the
    Similar Build I guess to the S905 H96 projector reviewed a while ago, but this one has the Amlogic 905X Chip
    Spec's and Parts are much the same, give or take
    Lets have look
    The Box
    What's in the Box
    Look around
    Remove the Top.
    Remove the Base
    Look under the Battery, not much
    Remove PCB
