Hello First time poster long time reader. I have a question. I have noticed that the nvidia shield android tv box with android version 7.0 can use usb OTA tuners to be able to pick up tv channels. so with that I though well, the t95k has android 7.1 so it should work. So I bought a tuner and tried it on my t95k pro but it does not work. I tried many apps and most don't even activate the tuner. One does Pad TV HD and it scans but doesn't find anything.
Has any one tried this before to see if it works on the boxes or have any experience with it at all? It would be great if this could be used on the boxes.
