JMGO is back with the M6, a portable 200 ANSI lumens DLP projector. Support 4K ultra HD / 1080P / 3D video playing,
this new product will give you an astonishing viewing experience.
With JMGO M6, taking a cinema with you anywhere and any place is no longer a novelty idea.
The JMGO M6 comes in a compact size that just looks like a lady’s hand bag.
Compared to the previous portable projector from JMGO, the M6 is much smaller. It measures just 194 x 102 x 29 mm and weights 500 grams.
Thus, it’s very convenient to put in backpack. The body of the JMGO M6 is made of ABS material and with premium gold coating.
There is a bar design on its side. By taking it down, you will find that it’s actually the IR remote control.
And the LED lamp and speakers are hidden behind it. This 2-in-1 design makes the M6 more portable because you don’t need to independently take the remote controller.
On the other side, there is a plug-in design for installing the smartphone. You can share your content with your mobile phone easily. JMGO M6 is compatible with phones of Micro USB, Type-C or Apple lightning interface. The JMGO M6 also features an HDMI port for computer / PS4 / XBOX connecting.
JMGO M6 Specs
Display type | DLP |
Native Resolution | 854 x 480 |
Resolution Support | 1080P / 4K |
Lamp | LED, 22W (20000H life time) |
Brightness | 200 ANSI Lumens |
Contrast Ratio | 3000:1 |
Throw Ration | 1.2 : 1 |
Projection Distance | 0.5 – 3 meters |
Image Size | 30 – 120 inches |
Image Scale | 16 : 9 |
Support Formats | Picture Formats: JPG / PNG / BMP Video Formats: MPEG1 / MPEG2 / MPEG4 / H.264 / HEVC ( H.265 ) / DIVI / VC1 / RM / AVS / AVS+ / VP8 / VP9 Audio Formats: MP1 / MP2 / MP3 / WMA / OGG / AAC / M4A / FLAC / APE / AC3 / AMR / RA / WAV |
Power Supply | 100-240V |
Bluetooth | No |
WiFi | Yes |
Built-in Speaker | Yes, 30dB noise |
DVB-T Supported | No |
External Subtitle Supported | Yes |
3D | Yes |
Product weight | 0.5000 kg |
Product size (L x W x H) | 19.40 x 10.20 x 2.90 cm / 7.64 x 4.02 x 1.14 inches |
Package Contents | 1 x M6 DLP Projector, 1 x Remote Control, 1 x Universal Power Adapter |
