MeLE PCG03 Plus advanced BIOS setting Problem
    I changed the PCG03 Plus advanced BIOS setting:”
    1. auto detect lpddr3 rom” from enable to disable.
    2. “lpddr3 chip select” from 1rank to 2 rank.
    After restart, the PCG03 Plus can‘t work!!! the indicator lamp was blue ,but no vga sign,no boot logo~usb keyboard only power lamp on,no reaction to click the Caps Lock or NumLock button. I try to remove the BIOS battery to resset the BIOS,but there is uselesss!
    Is there anyone can help me???
