Does anyone has this problem?
hi guys. i have a gt1 ultimate 3/32 with serial a706D0 . i have bought this box at 11.11.2017 but since then i couldnt use it even once because it has a online video play problem. i have uploaded a video to youtube . here is the link: https://youtu.be/Y6uvrUjcaUs . i have the lastest offical firmware. actually i have tried a few firmwarea but didnt work on a706d0. i think i habe to wait someone to come with a new firmware. videos which are at the box are workinf fine but online videos are not working.... does anyone has a solution?Last edited by gefattern; 05 February 2018, 02:39.Tags: None
Originally posted by Thusemhi guys. i have a gt1 ultimate 3/32 with serial a706D0 . i have bought this box at 11.11.2017 but since then i couldnt use it even once because it has a online video play problem. i have uploaded a video to youtube . here is the link: . i have the lastest offical firmware. actually i have tried a few firmwarea but didnt work on a706d0. i think i habe to wait someone to come with a new firmware. videos which are at the box are workinf fine but online videos are not working.... does anyone has a solution?
Does issue occur with both wifi and Ethernet?
Is it all video content types, from any site?
Is it using a web browser, or a dedicated app?
Does the issue only happen with HD playback?
Please post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
-i dont know what u mean with content types but it is the ---same from any site
-both web browser and app. twitch periscope facebook some movie apps. only youtube app works well all other apps are not playing videos.
- both sd and hd.
i have tried to play 1080p videos with youtube app. it worked well. there is no problem about youtube. ( i dont remember how youtube was working on web browser)
also i have tried 4k video which was in tv box it worked well
there is problem about only online videos on both web browser or app BUT ONLY youtube works well... maybe a codec problem...Last edited by gefattern; 05 February 2018, 02:37.
Originally posted by Thusem View Post
-both wifi and ethernet. wifi is weak also..
- both sd and hd.
do you mean Netflix and similar , or what , ever tried one of the CustomRoms for your Box , like this :
http://freaktab.com/forum/tv-player-...ndard-ultimate
this shall help i think .
greetings / gefatternLast edited by gefattern; 05 February 2018, 02:37.
pls watch the link i put in first post. it shows my problem very well. i have tried to load some firmwares. all of them gave errors at %5 %15. i couldnt open it for a week . finally loaded offical rom for a706d0 and worked again but it still has that video play problem. are u sure this rom works with a706d0 serials?
i dont have netflix account so i didnt try it. i have tried periscope, facebook, twitch, a few movie app, they were all had the same problem. only youtube played video well.
i am not sure , no Dev. , but before u start or not u can ask there .
I believe you're correct. I too have noticed a significant drop in video resolution when streaming, compared to the first original factory F/W. I'm now running the non-tv Nano Nexus ROM by Magendanz', found in the "firmware" threads of the GT1 section of forum. With the exception of YouTube and the Google Play Movies & TV app, which play flawlessly, all other streaming is knocked back in res.
The factory fw blend was terrible, and it's only advantage was in stunning video playback. At first I thought it was my modem speeds dropping off. It isn't a bottleneck in through-put, as the Google apps prove. I have stable network speed. The issue has to be in the processing of the video itself. Seems a shame, the FW I'm using is stable but I lose 1080p stream capability. I'm fairly certain it isn't even cranking 720p from Netflix. Netflix on my MK802iv gives higher resolution, but choppier framerate.
I can only hope this improves with future firmware....Please post your h/w & s/w as signature to help community with troubleshooting problems.
Originally posted by mechaone View PostI believe you're correct. I too have noticed a significant drop in video resolution when streaming, compared to the first original factory F/W. I'm now running the non-tv Nano Nexus ROM by Magendanz', found in the "firmware" threads of the GT1 section of forum. With the exception of YouTube and the Google Play Movies & TV app, which play flawlessly, all other streaming is knocked back in res.
There are currently 2643 users online. 2 members and 2641 guests.
