How to proceed? Thanks.
Unbrick MXQ-4K (R329Q_V3.0)
Hello, sorry for my english. I'm have a question, how to unbrick my device? I tried installing a custom rom and the process failed in "test device" then I canceled the process. So the device will not turn on, it will have red and blue LEDs light. In rockchip batch tool, when i connect the device with the OTG USB cable, the First Square Its BLUE, And in Android tool, show's me "Found one maskrom device".
How to proceed? Thanks.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by gefattern View PostHi ,
that is simple , if Flashtool is started and the FW is loaded press restore and wait till it is finisched ,
exit Flashtool , exit Box , connect to TV and set up your Box new , hopefully .
please report , greetings / gefattern
Greetings
Originally posted by lucasgabiatti View Post
Thanks for the quickly answer. I got "IDB fail"
Greetings
take AndroidTool 2.35 , run as Admin , take second Tab , load FW , of course Box must connected , then "erase Flash" and wait till
ready after that press "upgrade" wait till ready , same as before , now hopefully restore your Box on TV .
Hi ,
Can my usb otg cable just charging and not transfer data?
thxYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Hello, i try this method, and got this:
thx
please check on third Tab the Tests for IDB and others , the Offset must 1-4 Sectors so total 5 must shown ,
Sector 0 , 1 , 2 , 3 , 4 , and check the Log files about Error Messages about IDB , maybe your IDB is bricked ???
You are not sure to use the right USB Cable ??? if , use the one that came with the Box .
Please upload or link the Rom that you used , to see in Tool , maybe you can help another User with it . Thanks
Originally posted by manu_manu4 View PostWhat's the name of the rom you are trying to restore ?
I follow this steps: https://www.youtube.com/watch?v=ogLAc2t_SIc&t=589s
ROM link: https://mega.nz/#!NPZWnLIa!5ZAHEoTKh...XrS78YOtECMl-4
Hi ,
10:54:31 186 Layer<2-1-3>Download Boot Start
10:54:33 414 Layer<2-1-3>Download Boot Success
10:54:33 421 Layer<2-1-3>:Wait For Maskrom Start
10:54:33 886 Layer<2-1-3>:Wait For Maskrom Success
10:54:33 895 Layer<2-1-3>:Test Device Start
10:54:33 903 Layer<2-1-3>:Test Device Success
10:54:33 911 Layer<2-1-3>:Get FlashInfo Start
10:54:33 918 <LAYER 2-1-3> INFO:FlashInfo: 00 00 00 00 00 04 04 00 28 00 00
10:54:33 926 Layer<2-1-3>:Get FlashInfo Success
10:54:33 935 Layer<2-1-3>:Prepare IDB Start
10:54:33 942 <LAYER 2-1-3> ERROR:PrepareIDB-->No Found 1st Flash CS
10:54:33 952 Error:Layer<2-1-3>:Prepare IDB Fail
10:54:15 980 Error:EnumerateHubPorts-->DeviceIoControl failed,err=0x48f
ROM Name: A95X_R1_SSV6051P_complex_tvmc_change_100_ddr624_up datewifidriver_RK3229_6.0.1_201700704
10:53:55 070 AndroidTool v2.3.5.0 start run
i am really not sure if you can restore it , can u make the IDB Tests under "AdvancedFunction" ???
Hi ,
What I have noticed is that even pressing the internal pin on the AV input when i connect the usb otg cable or not I have the same message on the android tool "Found one MASKROM Device".You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Guys! Problem solved!
It was only the wrong ROM.
I use the: LeelboxRK-8703-7.1nv3-kodi-1225 .img
Link: https://mega.nz/#!wrwyXYxD!0q0yVDFfT...FRiFYl_mUkVbTE
This rom isn't native from my box, but runs flawless! Upgrade succeed, thank you guys!Last edited by lucasgabiatti; 08 March 2018, 14:13.
lucasgabiatti, tenho o mesmo aparelho com o mesmo problema 'Prepare o BID Fail' alguma outra ROM sugerida? Obrigado.
There are currently 2439 users online. 2 members and 2437 guests.
