Just received my H96 pro 2/16 dongle, seems to have a blue pcb design and only 2 chips behind the heatsink, as of the traditional devices that have 3.
I wanted to reflash it with SuperCeleron's release but I accidentally left the "erase bootloader" option. The flash went well, however now the stick is dead and doesn't wanna start at all.
Pressing the reset button and connecting it to the AMLogic USB Burning tool does not work - it does not get detected at all. I tried doing that with the male-to-male cable on both USB ports and also with the MicroUSB one.
I also found a firmware version for that and made a microsd card with it with the Burn Card tool, pressed the reset button and then connected power and nothing on the monitor (should I disconnect the HDMI?).
No pins to short around the flash, it's a BGA and the pcb is pretty clean around.
In all cases, the red LED is on. However, nothing further happens...
Should you have any idea, please help.
Thanks!
