T95Z 3Gb+32Gb bricked
    Hello everyone,
    first of all my apologies if I ask this really newbie request for help but I really searched into the forum without finding useful information because there were too much and I didn't know what was the right thing for me.
    Actually I bought a T95Z 3+32 in November, worked properly till yesterday than today I had the device with blue light and blank screen.
    I tried to restart, power off, disconnect from everything and reconnect after a couple of hours but the situation didn't change
    I read a little bit on some forums and on a youtube video, download what I think it was the latest vendor firmware but when I tried to connect the device to the PC through the USB port to use USB Burning Tool 2.0.5.15, it doesn't detect the device (i followed the video guide).
    At this point I'm really stuck, can anyone pleas give me an hint?
    thank you very much in advance
    best regards
    DR
    Hi ,
    what Windows do u use ??? , for flashing , best is Win7 .
    Try a newer Version of Burningtool .
    greetings / gefattern
      Hi, I use Windows 10, I tried the procedure also with version 2.0.8 without any success
      thanks
      Daniele
        toothpick metod can be tricky ... how did you done it? can you write about it?...
          Apologies for the late reply but I got the flu.
          Actually I followed this video:
          I also got the latest formware and USB Burning tool from the vendor but still not working.
          Actually if I unpplug and replug power from the box several times, after some trial (10-11) it starts properly, but it's a pain
          thanks
          Daniele
