The Oukitel Mix 2 is one of the clones of the Xiaomi Mix2. A remarkable Design, curvings and edges just in the right place, not a lightweight at all, because of the metal frame, the glass backside and a battery with 4080 mAh capacity. Particularly pleasant is the screen, which appears very sharp and bright with a resolution of 2160x1080 pixels. The screen is almost borderless therefore, except at the bottom, because there the camera is installed.
~Introduction video ~
--- Time for the specs ---
~CPU Platform~
Cores: 2.39GHz, Octa Core
CPU: MTK6757V - Helio P25
External Memory: TF card up to 512GB
GPU: Mali T880
RAM: 6GB
ROM: 64GB
~Network~
2G: GSM 1800MHz,GSM 1900MHz,GSM 850MHz,GSM 900MHz
3G: WCDMA B1 2100MHz,WCDMA B8 900MHz
Network type: FDD-LTE,GSM,WCDMA
WIFI: 802.11a/b/g/n wireless internet
Wireless Connectivity: 3G,4G,Bluetooth,GPS,GSM,WiFi
4G LTE: FDD B1 2100MHz,FDD B20 800MHz,FDD B3 1800MHz,FDD B7 2600MHz,FDD B8 900MHz
~ Display ~
Screen resolution: 2160 x 1080
Screen size: 5.99 inch
Screen type: LTPS
~ Cameras ~
Back-camera: 16.0MP + 0.3MP ( SW 21.0MP + 2.0MP)
Camera type: Triple cameras
Front camera: 8.0MP ( SW 13.0MP )
~ Media Formats ~
Games: Android APK
Music format: MP3
Picture format: BMP,GIF,JPEG,JPG,PNG
Video format: 3GP,MP4
~ Additional Features ~
3G,4G, Alarm, Bluetooth, Browser, Calculator, Calendar, Camera, Fingerprint recognition, Fingerprint Unlocking, MP3, MP4, WiFi
Bluetooth Version: Bluetooth V4.2
Google Play Store: Yes
I/O Interface: 2 x Nano SIM Slot, 3.5mm Audio Out Port, Micophone, Speaker, TF/Micro SD Card Slot
Sensor: Ambient Light Sensor,Geomagnetic Sensor,Gravity Sensor,Gyroscope,Proximity Sensor
~ Battery ~
Battery Capacity (mAh): 4080mAh
Battery Type: Non-removable
~ Dimensions and weight ~
Package size: 19.70 x 11.30 x 5.70 cm / 7.76 x 4.45 x 2.24 inches
Package weight: 0.5100 kg
Product size: 15.78 x 7.50 x 0.88 cm / 6.21 x 2.95 x 0.35 inches
Product weight: 0.2078 kg
~ Package Content ~
Back Case : 1
Cell Phone: 1
English Manual : 1
Power Adapter: 1
SIM Needle: 1
--- Properties in Detail ---
CPU and Graphic Power +++ |
~ The MTK6757V - Helio P25 has enough power for daily use in internet, office and social media connectivity, ~Gaming is not a problem at all with this upper middle class CPU and the Mali T880 GPU ~ Antutu result is impressive with 80520 points ~ Gamer Benchmark: Sling Shot Extreme Open GL ES 3.1 result is 700 points ~Geekbench Score: Single Core 816 points ; Multi Score 3763 points |
Memory +++ |
~ 6GB RAM and 64 GB ROM will leave nothing to be desired |
Connectivity +++ |
~ The Wlan is fast and has a good range ~ 4G is available works fine ~ Bluetooth connects fast and stable ~ GPS is working fine for google maps |
Screen +++ |
~ The 5.99 inch screen is a colorful an bright in FHD+ 2160x1080; very sharp ---> an outstanding screen ~ The menu buttons are on screen ~ Touch of the screen is very responsive |
Audio +++ |
~ The Speaker sound is clear, well balanced for an phone speaker ~ Over ear/head phone I notice the full sound experience, tested with xiaomi earphones, AKG K240 headphone and Phillips BT Headphone ---> a clear, noiseless well balanced sound is always the result ~ BT Audio works fine in good sound quality over BT Headphones without drop outs or disturbing backround noises |
Camera ++ |
~ Cameras are doing a good job, video signal in hangouts in natural colors and smooth, snapshots are sharp and natural of course in daylight or indoor when the light is bright enough, don’t expect the perfect selfie shot, in critical light situations pictures get noisy, the back camera is much better in details and natural colors |
Battery ++ |
~ With the 4080mAh battery about 2 days in average use are possible ~Of course with the big battery comes the 207g total weight of the phone ~For an Oukitel upper class phone is a capacity of 4k Battery power more entry level style :-) |
Android +++ |
~ Ouktitel Android 7.0 with the security updates from January 2018 comes with the basic apps, but with google play you can add all your favorite apps. ~The firmware performs very good, the helio P25 is a powerful CPU from Mediatek |
--- Resume ---
With a price around 200 USD it is a nobel smartphone without any remarkable issues. For sure on of the best Mix 2 designs. The hardware with the Helio P25, Mali T880 and an outstandig FHD+ screen give you a great experience in power and design. What else do we need.
For More Details ---> Oukitel.com
Right now in the Flash Sale on Gearbest.com
