Can you specify all those that are compatible with the H96Pro 2GB / 16GB dongle?
[SOLVED] Amlogic S912 H96 Pro TV stick dongle mini PC bricked
Did You try pushing reset button? It can take few tries to fully flash the firmware. Just push the reset when it stops at 2-4% with error and do not touch anything - You don't have to stop/start flashing process again, after it finds the device was reseted, it will start over.
ZUK Z2 Pro ✓ᵛᵉʳᶦᶠᶦᵉᵈ
ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by deiab View Posthello, i breaked my tv dongle. tried several firmware via sdcard but its hang at upgrading screen
i can't use burnning tool because it not detected by pc. any suggestions.
I have the same problemwith my device H96 pro stick s921 ,bricked,
whenever I try to install the system file stands at 4% once an unknown error appears [0x11000902] and error 0x10303004 appears, I tried All the ways I did not succeed in the installation as well as you have installed all the firmwars of the device H96 pro is useless every time this error appears,
I hope I find help in solving this problem from anyone have info
(:. Thanks
There are currently 2587 users online. 1 members and 2586 guests.
