H96 Pro+ U-Boot problem
Hi there, is there anyone who is running LE on H96 Pro+ and are able to turn the box on with their remote. Can you please confirm which box version you have and what Android FW you have installed? Not sure why the other post discussing this topic has been closed :-(H96 Pro+ 3/32 CZ-S32-V5 BLUETags: None
I think the problem is that LE is generic firmware, so all the settings are generic one and H96 may use nongeneric config for it's remote.
If there is an remote config file in LE firmware than it may be possible to edit it with data from config from official firmware?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Here's a link to an amended Android ROM (Wisdom), in which the fixed u-boot.bin_DDR3@792Mhz has been already incorporated and it's been tested on green v2.2 H96Pro+ board with normal DDR3 (not LPDDR3):
S912_H96_3G_DDR34_171120_MAC_ubootfix.7z
Flash the ROM via USB Burning Tool v2.1.2 or Burn Card Maker v2.0.3 on your own risk, of course.
There are currently 1210 users online. 1 members and 1209 guests.
