XIAOMI Mi Box 4 Android 7.1 Amlogic Cortex-A53 Quad Core 64bit 2GB/8GB 4K HDR TV Box Dolby DTS-HD 2.4G WiFi Bluetooth Voice Remote Control - Chinese Version
Android 7.1
XIAOMI Mi Box 4 is based on the Android 7.1 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
Quad Core Amlogic Cortex-A53 CPU
A high performance of Quad-core 64bit 1.5GHz Amlogic Cortex-A53 CPU can play a wide range of games.
DDR3 2GB RAM, eMMC 8GB ROM
It is configured with DDR3 2GB RAM, and eMMC 8GB ROM, thus it can provide enough room and freedom to install Apps without worrying about running out of space.
Just speak into the remote control and XIAOMI Mi Box 4 will search for what you want.
DTS-HD and Dolby Surround Sound
The Mi Box 4 supports both Dolby audio and DTS-HD audio encoding. The result is smoother, dynamic, immersive and more realistic stereo surround sound during ultra HD Blu-ray video playback.
HDMI 2.0 Connector
You can go directly to let your TV and Mi Box 4 connect through an HDMI cable and set up your home cinema for the best 4K*2K UHD multimedia experience.
4K Resolution & HDR
It supports decoding of H.265 4Kx2K@60Hz, which upscales and enhances every pixel for remarkable clarity. Furthermore, it supports HDR technology, so the video image is clearer. High definition pictures and videos offer you the extreme visual feasts, all the details will be caught by your eyes.
Specification
General | Brand: XIAOMI Model: Mi Box 4 Type: TV Box Color: White Material: PC+ABS |
Hardware | OS: Android 7.1 CPU: Amlogic Cortex-A53 Quad Core 64bit 1.5GHz GPU: Mali-450, 3+2 Core 750MHz RAM: 2GB ROM: 8GB eMMC |
Communication | WiFi Connectivity: 2.4GHz, 802.11b/g/n Bluetooth: Bluetooth 4.1+ EDR (enhanced data rate), BLE |
Media | Video Supported: H.265 4Kx2K@60Hz; H.264 4Kx2K@30Hz; MPEG1/2/4, VC-1, DivX4/5; 1920*1080P@60Hz; Support HDR 10 Video Format: FLV, MOV, AVI, MKV, TS, M2TS, MP4, 3GP, MPEG, OGM Audio Supported: Dolby Audio, DTS-HD Supports MP3, APE, Flac, AAC, Ogg Picture Supported: JPG, BMP, GIF, PNG etc. |
Interface | HDMI Port: Standard HDMI 2.0 Other Interfaces: 1*HDMI 2.0 2*USB2.0 1*AV 1*DC |
Other Feature | Supported languages: Chinese only |
Power | 100~240V 50/60Hz Input; 5V/2.1A Output |
Dimensions&Weight | Weight: 145g Dimension: 95mm*95mm*16mm |
Package Contents | 1 x TV Box 1 x Bluetooth Voice Remote Control 1 x HDMI Cable 1 x Power Adapter (A right AC Adapter will be sent as your shipping country) 1 x User Manual |
Use the coupon:BHNMTHKU
Shop now:https://goo.gl/wyAaiT
