This ROM is based on the official iFive firmware dated 2/21/2013.
Features:
Full Root
Expanded Ext4 system.img
Debloat
Init.d support
Busybox commands added
Boot Animation by Tattman65
Reboot app by Petrus
This ROM kit also contains a template for creating a CWM flashable zip file, but you can't use it on the first flash. This ROM must be flashed by a PC the first time to set up all of the parameters.
The default recovery is stock, but I included the generic CWM Recovery to try if you want...I haven't tested it.
Here is the download link:
iFive X RileyROM 1.0
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
