Hystou FMP05B Intel Core i7-7500U 8GB RAM 256GB SSD 4K Fanless Mini PC 2.4G WiFi Bluetooth Gigabit LAN HDMI+DP 4*USB3.0 SATA
    Intel Core i7-7500U
    The Intel Core i7-7500U, a dual-core processor based on Kaby Lake architecture, offers 2 CPU cores clocked at 2.7 - 3.5 GHz and integrates Hyperthreading to work with up to 4 threads at once.
    DDR3 8GB RAM, 256GB SSD
    8GB RAM makes bigger games run smoothly and the utilization of 256GB SSD offers an array of benefits in terms of performance security and reliability, resulting in a richer end-user experience.
    Gigabit LAN & WiFi
    Gigabit LAN provides a data rate of 1 billion bits per second.
    300MB WiFi with 2 Antennas.
    mSATA and SATA
    Onboard mSATA and SATA port support SSD+HDD dual storage.
    Applications
    Office Work: Office, skype, yahoo, outlook and all other office requirement support and runs perfectly.
    Design Work: Photoshop, CoreIDRAW, Dreamweaver, ILLustrator, Flash, Indesign and others.
    Game Playing: Support most of the online games and PC games, like Warcraft, Counter-Strike (CS), support 3D games.
    Entertainment: Support 4k video play, XBMC and others.
    Specification
    General Brand: Hystou
    Model: FMP05B
    Type: Mini PC
    Quantity: 1 Piece
    Color: Black
    Hardware Supported OS: Windows 7, 8, 10 & Linux Compatible. The default OS with the Mini PC is Windows 10, please leave order message if any special requirement.
    CPU: Intel Core i7-7500U Processor (4M Cache, up to 3.50 GHz)
    GPU: Intel HD Graphics 620, support ultra HD 4K resolution max 4096x2304@60Hz
    RAM: 8GB DDR3, support 2GB/4GB/8GB/16GB(2*8GB) DDR3L SODIMM laptop memory
    ROM: 256GB SSD, support mSATA and SATA SSD; 2.5 inch laptop HDD; Can install 1*HDD(2.5 inch) and 1*SSD(mSATA 3.0) together
    Communication WiFi: 2.4GWiFi, 802.11b/g/n 300MB WiFi with 2 Antennas
    Ethernet: Gigabit LAN
    Bluetooth: 3.0(optional)
    Interface 4*USB3.0
    1*USB2.0
    1*HDMI
    1*DP
    1*Speaker
    1*Micphone Jack
    1*DC IN 12V
    1* SD Card Slot
    1*SATA Port
    1*MSATA Port
    1*RJ45 Gigabit LAN Port speed up to 1Gbps
    Other Features Language: Multi Language
    Feature: Fanless
    HD Output: 1*HDMI port+1*DP port, support 4K output, support HDMI+DP dual display
    Power DC IN 12V
    Dimensions & Weight Product weight: 1.8kg
    Package weight: 2.7kg
    Product size: 23 x 18 x 5cm
    Package size: 31.5 x 26 x 8cm
    Package Contents 1 x Mini PC
    1 x Power Adapter (A right AC Adapter will be sent as your shipping country)
    1 x Charging Cable
    1 x User Manual
    Check it:https://goo.gl/7AXhVx
