It can be hard to find which image You need. I think all 3/64 are S32-V5 or V6, so here are roms for V5: https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!prxFnCRA
Think they will work with V6 too. As for now there are no images for V6. I have TWRP backup of my firmware (3/32 V6), but that's all there is.
To be sure if Your is S32-Vx, You should open the Box and check PCB name (if it's blue than it's S32).
Small pictures
You have S32-V6. Supercelerons roms should work (the y are on my 3/32 S32-V6). They are better than original firmware.
As for Netflix, it won;t work on H06, as it doesn't support Wideline L1. That means that Netflix ATV won't launch adn mobile app will only work with SD resolution.
Small pictures
Sorry i replied after your reply ...just give me the link as im very noob what do u mean by supercelerons ?! Team or Rom or what ?
For netflix i mean with subscription i dont mean I need to open Netflix for free ... before this acciddent i open Netflix and login to my account and everything fine
Plz only give me the correct link to download and small steps to flash it on the device
I have sd card and flash memory and laptop with win 10
2-app button & setting button on remote control not working
3- usb mouse with Youtube app not working !
4- no option to change the video quality on YouTube app
5-no edroid settings as original
6-no kodi installed i saw another app
This samples
I will try your backup also i found this post contain a different ROM from gearbest can you check it maybe this what u asked them and if tested before what is the difference between your backup and this ? Also how to recover your backup fro twrp ?
