Nexbox A95X
    Nexbox A95X
    Hello I'm French !
    I have the Nexbox A95X-B7N (2gb / 8gb)
    I try to install Android TV on it, but as the DRM wasn't included in the firmware I installed, I try to put DRM manually in the box... But since this moment the box have lot of problem.
    So I decided to install the official firmware with a SD card, but, no way, the box boot directly on the "nexus" logo, then Android then ATV... I installed a reboot apk, and under twrp, I deleted system directory etc... Now my box show only the Nexus logo all the time...
    I tryed with a usb stick, no way, I bought a USB - USB cable, but, the box is not visible on my computer with USB Burning Tool
    What can I do now, because, my box is ... out of order ! ?
    Thanks for your help,
    Have a nice day.
