Another H96 pro+ thread (I am not a newbie) :)
    For start let me thank you for all the great info you shared on this forum.
    I have bought H96 Pro+ some months ago and I just discovered this forum and threads. So I am about to start messing with my box.
    I am familiar with all the flashing procedures and stuff so I will not waste your time with things that are already on the forum.
    I want to ask you certain things.
    Which firmware are you currently running? For how long? Can you suggest things i must do to get the most out of this box? I am familiar with Kodi stuff but lately most of the sport streams are not very stable.
    My only complain is about the WiFi reception. I think the antenna is kinda small. My WiFi router is a TP-Link Archer D2 with 3 big antennas using 2.4Ghz 5Ghz dual band g/n/ac compatible.
    Some more details on my box.
    Build NHG47L.20170809
    Green PCB CZ-S32-V2.2
    20161012(A15)
    W02170801/3+32+9377
    4 usb ports (2 hidden from plastic case but working)
    Big aluminum heatshield with edges
    I am thinking of flashing with XCYgood
    aml_7.1.2_s912_q9377-S912_XGO_mac-20171206.7z with this guide
    Is all the above correct?
    Thanks for all your help and waiting for your replies.
    20161012(A15)
    W02170801/3+32+9377
    http://freaktab.com/forum/tv-player-...o-any-s912-rom
    Hi ,
    what about Supercelerons Rom for this Box , good Dev. , look here :
    http://freaktab.com/forum/tv-player-...7-wifi-chipset
    but be patient first read , there are several Version of this Rom & PCB , good luck ,
    greetings / gefattern
      Hi ,
      Hi man. Appreciate the super fast reply.
      I have read Supercelerons Rom. The thing you say about several versions is what made me wait for answers on this topic.
        Hi ,
        i only mean that there are SCV1 - SCV4 / A and only DDR3 Roms of SC for this Box , but if i see your Specs , i think it fits ,
        but you can still ask there first , but always first backup , before you start with any Rom you want try .
        good luck / gefattern
          Hi ,
          Yeah i think it fits too. Have doublechecked the images and details of my box.
          So i just proceed with USB burning tool and flash Green SCV4 and then SCV7A. I prefer SuperSU to Magisk. What's your opinion between those 2?
            Hi ,
            i am not sure , but please dont use SuperSU on this Box , i think it will brick after update ,
            if Magisk works better , so use this , but ask for sure once more Superceleron , he knows
            more about that !!!
              Just finished installing SCV4 and SCV7A.
              Box is awesome fast! Though there are some bugs. I ll search this custom firmware more and be back with my findings.
              2 serious bugs I have encountered.
              - Miracast trying to connect but fails
              - Physical Remote Keyboard (Logitech usb) is kinda buggy on some field typing.
                A1. Miracast doesn't work on superceleron's roms. Or it's more like if it wotks than it works, but it probably won;t.
                A2. No problem with my LogiLink BT keyboard as well as with AirMouse with USB dongle.
                ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
