Can't boot from USB on wintel W8 z3735f
as per title - have a dual boot wintel W8 (win10 and android) - i want to remove android and install fresh windows across the whole 32gb flash. i can get into bios and change boot order but it keeps booting into windows - any ideas how can i get it to work?Tags: None
Originally posted by bluesmanuk View PostCheck that you can boot the USB flash drive from another machine as not all USB sticks support the ability to boot from them.
I think you need to delete the android partition use a Linux distro boot to bios and choose boot from file option , choose linux usb , then efi , once Linux booted delete all partitions with gparted , reboot to bios with Windows installer usb again boot from file choose windows usb , efi , boot32 file and install on whole 32gb
So you have a UEFI Bios.
See if this helps.
https://www.windowscentral.com/how-create-windows-10-usb-bootable-media-uefi-supportR-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostSo you have a UEFI Bios.
See if this helps.
Originally posted by jimennis View PostI think you need to delete the android partition use a Linux distro boot to bios and choose boot from file option , choose linux usb , then efi , once Linux booted delete all partitions with gparted , reboot to bios with Windows installer usb again boot from file choose windows usb , efi , boot32 file and install on whole 32gb
I have wintel pro like you it won't boot usb straight I have too find in the bios the boot from file option which lists the partitions , I choose the usb and find the efi directory from there I can boot any usb once it has an efi efi boot . You could try mounting your installer inside your booted windows and hit the install exe thatwill start the install and maybe the option to partition
Originally posted by jimennis View PostI have wintel pro like you it won't boot usb straight I have too find in the bios the boot from file option which lists the partitions , I choose the usb and find the efi directory from there I can boot any usb once it has an efi efi boot . You could try mounting your installer inside your booted windows and hit the install exe thatwill start the install and maybe the option to partition
Originally posted by trebor View PostI did a long time ago, it may still be relevant and work...
http://freaktab.com/forum/tv-player-...box#post506228
There are currently 2070 users online. 1 members and 2069 guests.
