What roms ACTUALLY work with this????
    OK
    There seems to be different version of the SAME box so my question simply really.
    What work with this BOX https://www.aliexpress.com/item/Genu...311.0.0.N0Qy1H
    Just list the roms/custom roms for this box that will work..
    If other folks want to know about a different box them CLEARLY make sure you show/indicate which box you are refering too so as to NOT confuse the thread...
    thank you
    I am sorry but your link not work.
    how about posting an name?
    Will more help.
    Betonidee
ID:	711557Click image for larger version
      Will more help.
      Betonidee
      works for me!!!
        Hello,
        Here you find the Firmware for your Device:
        Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
        You can Burn it to the Box with the USB Burning Tool you find here:
        FileFactory is the best place to upload and share files with no limits since 2005. Send and receive any type of file up to a massive 5GB with unlimited file bandwidth.
        Regards
        Neomode
          Hello,
          Regards
          Neomode
          Hello I can flesh on the model 2gb ram 16gb rom?
            No it is for the 1GB Version.
            Wait I will post 2GB Version.
            Regards
            Neomode
              Okay here it is:
              Neomode
                Okay here it is:
                Neomode
                usb burning tool gives me this error rom code / initialize ddr / read initialize status / usb control setup error
                  Then try to flash with power supply.
                  Sometimes the power of the USB port is not enough.
                  Neomode
                    Neomode
                    and how should I do? when i flash the x96 mini firmware this error did not give it to me. the problem is that now I have mounted the firmware of the x96 mini in 'x96 and I would like to reassemble the original one. Sorry for my English
                      Hello,
                      X96 and X96 mini are different.
                      One is S905x the other is S905w.
                      I don´t think you can interchange the Firmware.
                      Start USB Burning Tool, Load the Firmware don´t press Start.
                      Connect USB to the Box. USB Burning Tool detects it.
                      Now Connect the Power Cord and press Start.
                      Neomode
                        Hello,
                        Neomode
                        it does not even go. I rewrite my problem in order to understand each other better. my model is x96 with amlogic s905x processor, originally when I bought it, the initial screen started with the x96 screen. after an app that I installed the box went in brick and I tried to flash the firmware found on the site. the only one that has a successful flash and it works was that of the x96 mini falch with usb burning tool without problems. instead all the others I have tried usb burning tool gives me this error rom code / initialize ddr / read the initialization / configuration error status USB control
                          removed by user
                            no solution to my problem?
                              Hello,
                              I guess you have an X96 with S905w CPU then.
                              Also then you need an Firmware for that right?
                              Neomode
