v2.0
1.Corrected a few mistakes
2. Changed GO key as App Switch button
Download V2:
Vendor_03e7_Product_0d01.v2.txt
v1.0
Remapped
1. Esc as Play/Pause
2. DPADCENTER button changed from "Enter/LeftClick" to "OK", so as to work best for XBMC/any apps and support long press, etc
Disabled:
Game Mode Button
Learning Button
SoundOutput swap button
PickUpCall button and EndCallButton
P.S. If anyone can help to make the sixaxis "game mode" and "Soundoutput swap"works in e.g. CS918/MK888, otherthan Mele M9, i will appreciate to work together~~ thanks
install:
Root yr device first,
rename the file extension from txt/v2.txt to kl
unplug mele f10 pro
put the file in \system\usr\keylayouts\
set proper permission (same as other files in that folder)
replug yr mele f10 pro, should work as what i said
