Mecool M8S PRO L Smart Bluetooth Voice Control TV Box, VOICE REMOTE CONTROL (3GB RAM + 32GB ROM)
    Holidays over back to the Show and Tell
    Today a look at the Newer Mecool Pro L 3/32 with Voice Remote thanks to Gearbest
    Main Features:
    ● Combines durable 1.5GHz ARM Cortex - A53 CPU with Amlogic S912 chip
    ● Android 7.1 version, coupled with the rapid and stable configuration
    ● 4K / 3D video gives you high-quality video experience
    ● Dual-band WiFi gives you more smooth speed experience
    ● Bluetooth 4.1 connectivity. Easy pairing with most Bluetooth-enabled devices
    ● Support Miracast / DLNA / Airplay, share your video to your TV
    Looking Much the same as Previous except for a flash looking Voice BT remote.
    Lets get looking
    The Box simple as always
    A sticker on the back has the details
    What's in the Box
    The Remote
    Ports rear
    Ports Side
    Look Under
    Remove the Lid
    Out with the PCB and a look under
    Closer look Top Side
    Closer look other side
    Well this is Kinda Fun, Different, using the full ATV experience to set things up from start
    First we detect the BT Remote Hold - and OK as per screen instructions....and the remote is detected after a bit of a scan no hair pulling here.
    Setup up Google account Via Phone or tablet, why not
    Log into google via Tablet and find my device being the 912 pro L, few seconds done.
    Let's set up account and software (this is all done on tablet) ok do it what could go wrong.
    What wifi do you want the Pro L to use, picked one...all good.
    A few do you agree to this and that here and there (google stuff)
    Would you like to try the Android Remote on your table, sure gone this far not going to stop now.
    Loads shows a pairing code etc and done.
    Well that was a bit different and seems to work without any major hiccups or problems just read the screen.
    Of to playstore to do some updates load some testers and see what this has to offer in the way of performance.
    Haa Root explorer, Via Es file explorer Pro, being ATV no Upper or Lower Bars
    Aptoide ATV installed found most apps required for testing etc
    Good startup excellent evan for sure, nice, easy to follow and all seems to be working well with this Factory Rom
    and Netflix 1080
    Widevine L1
    Click image for larger version  Name:	nf.png Views:	1 Size:	153.8 KB ID:	711310
    More Can be Found Here >>>>> Freaktab <<<< click
    You can save $5 with Code: GBMCLB
