root android 7.1 kingbox
Originally posted by dobermann View Post
Great, my Box is prerootedhow can i install twrp and backup system ? thanks for the tip
dont know what kind of TWRP file do you have , a .img File must be flashed with AndroidTool 2.35
or higher , for backup your Apps you can use TitaniumBackup , not bad , ask if u need mor Info ,
greetings / gefattern
Hi ,
How can I do that whit android tool? Do you have any tut for me? Pls
first did you ever flashed a RK Box ??? , if :
u only have to use the first Tab of Tool , uncheck all , then recheck the "Recovery" row , on the end
of the row u can press and then select the TWRP from Folder where saved , of course all other
things like Drivers must be installed , connect Box to Tool & flash .
if not :
use big G and search for : Firmware Upgrade Guide for Rockchip devices , use the Ugoos Site and
first only read it , if u need more Info ask , but it is easy to do ,
good luck / gefattern
Hi ,
if not :
Originally posted by raulmax3 View Post
1. Is the first dl a backup ?
2. And this the twrp to flash ?
How i flash it ?
first , plug USB to PC ,
second , press the "Button" & hold it ,
third , plug in Power , wait for Sound of Flashtool or shows "found LoaderDevice" ,
that is all , of course you must before installed the Drivers & load FW to Flashtool ,
Hi ,
There are currently 6791 users online. 0 members and 6791 guests.
