mxq pro 4k 2GB/16GB s905x rtl8723bs - i need stock firmware without root
    Hello. Sorry for my english.
    I have machine:
    Is there an android 5.0 firmware for this device?
    Will this software be good for my equipment?
    http://www.chinagadgetsreviews.com/d...-tv-box-4.html
    the name and model match, but there is no information about the components for which this software is released
    To make it clearer, I need a factory firmware best without root, or such firmware that even after uploading, I will be able to perform a full unroot. Currently, on android, which I have 7.1 I can not perform a full unroot. I make it through SU and after rebooting everything returns to its original state. Root chcecker detects root.
    I have machine:
    No, s905x boxes are not compatible with android 5 firmware.
      thank you for the answer, but if there is any firmware, it does not matter whether android 6 or android 7, it's important that I can upload it and later that I can do unroot, because on the current version of the firmware I can not.
