I have this Android TV box (T95N Mini M8SPro) with 2GB RAM and S905 chipset. It is running on Android 5.1.1 (I thing, maybe it's 5.0.1.... never mind). I need to perform firmware update (reinstall) and I downloaded from chinagadgetsrevies site what it seems to be correct firmware.
Never the less, when I try to load image into USB Burning tool (2.0.8 version) I get message "Parse image loading fail" and it is happening with every single firmware I have found on different sites.
Does enyone know where I can find correct firmware?
Why do I get this message, how to solve that issue?
Thanks for help and reply
