[HELP] H96 Pro plus 3Go Rom 16GB S912 / CZ-S32-V6 [SOLVED]
hi ,
i need help , i can't firmware my box tv (H96 Pro plus 3Go Rom 16GB S912 / CZ-S32-V6) ,i tried with usb burning tool 2.08 +aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20170809 , i receive an error message on usb burning tool at 2% :
[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error.
Not even after 4-5 try? Are You sure Youy are using right firmware for Your variant of H96 Pro+? S32-V5/V6 are newer Boxes and they came few month after 2017.08.09, so it may be firmware for the wrong variant (like S32-V2.2/V3 or even other)...
yes, after 4-5 times it did not work , i did not found a firmware on the net to H96 Pro S32-v6, i want to change de firmware because when I plug on the tv, there is no picture and the blue led on the box remains lit
-It is necessary to launch usb burning tool
-choose your rom (for me , it's : aml_7.1.2_s912_q9377-H96PROPLUS_LP_mac-20171010.7z)
-Then connect the power supply and usb at the same time
-Press the reset button (he will be in uboot)
-then press "start"
and wait finish
-then press "start"
and wait finish
Could you post the rom link please, I did not find it on the forum.
