Need Urgent Help With H96 PRO + 32GB+3GB RAM
    Dear All
    I have H96 PRO + 32GB+3 GB RAM ANDRIOD BOX . the box have no light suddenly and i try to flash the box throw Burning Tools 2.05 and 2.0.8 and i am getting Error ( GET KEY FILE ) .
    http://www.mediafire.com/file/npfbx8...ES%20ERROR.png
    someone told me i need licence folder to install inside the burning tools folder . can someone provide me license folder .
    I need to fix the box as quickly as possible .
    Tanks
    Originally posted by abdulrehman690 View Post
    Dear All
    Tanks
    Hi ,
    ask User "Scooter2014" he knows the Link and how to ,
    good luck / greetings / gefattern
      Dear All
      Tanks
      Most probably you flashed the wrong firmware. It happened to me. The box switch off and won't switch on again after trying to flash an update. Good thing I found http://freaktab.com/forum/tv-player-...-chipset/page1
        You are certainly flashing wrong ROM, check the board color and download the green/blue firmware. I did the same and its fixed. Though you may need to check the power adapter as well if no light on adapter and you get the light on USB.
