RK3188 TV Box connection to PC
I have my android TV box RK 3188 connected to my TV and to my PC. In settings of the TV box I check the USB section to connect to pc and the box shows up on my PC. If I unplug the USB cable and plug it back in my PC does not see the box. While plugged in to the PC I uncheck the USB connect to PC and then check it on again my PC will see the box again. Why is this happening?
Tags: None
Originally posted by Tec-Diver View PostI have my android TV box RK 3188 connected to my TV and to my PC. In settings of the TV box I check the USB section to connect to pc and the box shows up on my PC. If I unplug the USB cable and plug it back in my PC does not see the box. While plugged in to the PC I uncheck the USB connect to PC and then check it on again my PC will see the box again. Why is this happening?
you have to uncheck "connect to Pc" and then unplug USB , if you do it without the
"unmount" is not correct , hope it helps .
greetings / gefattern
I was in a hurry when I replied and forgot to thank you for the advice. I also have another problem with this stupid box. If I check the box in USB settings to connect to PC and I power down the TV box, the box is unchecked when I power back up. Is there a way to make the box permanently checked to connect to PC?
Originally posted by Tec-Diver View PostI was in a hurry when I replied and forgot to thank you for the advice. I also have another problem with this stupid box. If I check the box in USB settings to connect to PC and I power down the TV box, the box is unchecked when I power back up. Is there a way to make the box permanently checked to connect to PC?
i am not sure , but it is normal that it is "unchecked" after reboot .
Gentlemen, I thank you for the information. If that is the case how can I flash the device and upgrade to Android 7.1.2 Operating System? The procedure is that the box needs to be powered down; put in a reset mode; connect to PC and install new software with the Rockchip Batch Tool. My PC will never see the stupid box. Any suggestions are greatly appreciated.
There are currently 1852 users online. 1 members and 1851 guests.
