I bought this H96 Max 32GB + 4GB in December...It will not pass the start screen "H96 Max" and I am losing patients with this $130 computer. I bought a high quality HDMI cable for it also...The only thing that comes to mind would be because the TV is only 720P? I have it out of the case as I put a high quality small copper heat sink on the 3399 proc. with good H.S. grease...I saw a video on Youtube and the guy said that first startup is kind of slow...I waited about 10 minutes and nothing...Any ideas are welcome...THANKS
Xinways H96 MAX (Android 7.1 installed Ver.) Stuck on first start Sreen!?!
Hi all,
I bought this H96 Max 32GB + 4GB in December...It will not pass the start screen "H96 Max" and I am losing patients with this $130 computer. I bought a high quality HDMI cable for it also...The only thing that comes to mind would be because the TV is only 720P? I have it out of the case as I put a high quality small copper heat sink on the 3399 proc. with good H.S. grease...I saw a video on Youtube and the guy said that first startup is kind of slow...I waited about 10 minutes and nothing...Any ideas are welcome...THANKS -
you can try to flash a new StockRom , i think you can find it here on Freaktab .
If you need more Info , ask . I do not think that your 720p TV is guilty for that ,
the Roms are set to "auto" Resolution , on first boot , i think ???
greetings / gefattern
There are currently 1789 users online. 0 members and 1789 guests.
