(Note: at this point, I don't believe it's an "M8S+" box which I understand from some posts it might actually be)
I looked through this site (and others I could find), and understand as a staring point that a "simple" reset to "Factory Settings" might help me make this box functional again. I've tried versions of the "toothpick" reset method with no luck so far. (I don't know if I'm using the correct sequence of steps, but I have tried).
That said, the basic symptom I have right now, that I'm trying to get beyond, is that when the box powers up ... I see a black screen then
a) a tiny and very brief flicker of activity in the lower left corner of the TV screen
b) then immediately the TV displays the MBOX "logo" ( / splash screen) ... but it doesn't change from this screen and display the actual MBOX app UI.
When I try the "toothpick" reset method, I'm expecting to first see the Android "recovery screen" options that I can see people have posted on this site, but I'm only getting to the MBOX screen which I expect is being displayed AFTER I'd expect to see the ANDROID boot "recovery options" screen}.
Any pointers / suggestions on how I can move beyond the MBOX "splash" screen? Why my "toothpick" Factory Reset" sequence doesn't seem to be giving me the expected results?
John
