that moves super slowly. Both are controlled by the arrow keys on the remote. But how do you change from one or the other ? I've fluked it a couple of times but only sure way it to power off, then the (better) block cursor starts up. Any info appreciated.
M8S MECOOL TV BOX
M8S MECOOL TV BOX
Just newly learning how to use this device and driven crazy with the supplied remote. The main screen has large cursor that moves between each icon, OR a mouse pointer
that moves super slowly. Both are controlled by the arrow keys on the remote. But how do you change from one or the other ? I've fluked it a couple of times but only sure way it to power off, then the (better) block cursor starts up. Any info appreciated.Tags: None
Many thanks Trebor, I get it now. The button appears to do nothing as the pointer only appears after you press that,then press an arrow key. Although when the pointer's showing it goes away immediately.
The blue block cursor can be hidden but testing right now it stayed on screen, so couldn't tell when it's restored (or not).
Originally posted by Akexander99 View PostMany thanks Trebor, I get it now. The button appears to do nothing as the pointer only appears after you press that,then press an arrow key. Although when the pointer's showing it goes away immediately.
The blue block cursor can be hidden but testing right now it stayed on screen, so couldn't tell when it's restored (or not).spanish dictionary online, json formatter tool
There are currently 3747 users online. 1 members and 3746 guests.
