yesterday received by M8S pro l.
Powered it, installed Wifi Air Mouse (work perfectly well with another RK3188 tv box). The mouse pointer is visible, I can select app and menu, but when I open app (i.e. Youtube or Kodi or Chrome) I can't use the mouse, the pointer is visible and moving, but clicking doesn't do anything, doesn't scroll, doesn't select. Using the remote is OK, I can select and click on items.
Tried with USB cable mouse, same issue.
The box is on factory ROM.
Please advice
