Ugoos Launcher 1.4.6 release
    Click image for larger versionName:	launcher146_1.jpgViews:	1Size:	112.5 KBID:	713088
    Main Article in Ugoos Blog:
    This update brings more stability and makes possible to use application with different and slow devices based on old Android versions. Feedback after Previous BETA release gives us huge information flow for new bug fixes and capability problems.
    Mostly, main changes affected to animation mechanism, making it much easier to process because it uses less RAM than previous version.
    Second important innovation is an extended theme’s pack for Launcher. Theme pack includes custom category icons, design elements, color schema and background. Themes’ server usually will be updated and extended with new theme packs.
    Categories customization
    Launcher settings give ability to add, create, delete and rename categories. There are several main groups (All apps, Options) users can’t delete, in order not get rid of all apps, but all other groups fully moderated.
    Weather
    Weather is a pretty simple function. Just need to input your city name and upper bar will start showing current forecast and temperature (degrees can be Celsius or Fahrenheit). You can choose frequency when launcher will update weather (half, one or two hours). Information about weather imported from public weather services. Weather settings located in “Options” category.
    Ugoos Launcher already available in Google Play and will be updated automatically on Ugoos Brand devices.
