Zoomtak Upro & Zoomtak Uplus stock firmware
    I have located and downloaded the stock roms for:
    ZoomtakUPRO fingerprint=Amlogic/q201_3G/q201_3G:6.0.1/MHC19J/20170606:userdebug/test-keys
    http://50.97.203.156/Firmware/ZoomtakUPRO.am.20170606.V8.1.5_needunzip.rar
    ZoomtakVPlusUPlus.fingerprint=Amlogic/q201_9377/q201_9377:6.0.1/MHC19J/20170913:userdebug/test-keys
    http://50.97.203.156/Firmware/Zoomta..._needunzip.rar
    Is there somewhere i should post them?
    the upro i flashed is a little newer than this one. i will get it uploaded tomorrow
    this the upro firmware 20170921
    https://mega.nz/#!xGwVCZwR!pRQ333YtS...EhWcM6jrJD_RQo
    and finally. zoomtak UPRO 6.0.1 to 7.1.2 Upgrade full factory image. it has the usb burning with it.
    USB BURNING TOOL ONLY !!!!!
    DO NOT FLASH WITH BOOT CARD MAKER
    https://mega.nz/#!dCA2mAYS!-GrKWuuTN...5wI3T94mQ4PU90
    Here is the uplus/vplus 6.01 to 7.1.2 upgrade file, this file is untested, but i got it from a reliable source
    https://mega.nz/#!kDQhVAAC!evXECKxNh...UBJzVKZYwusI5I
    new update for vplus and t8+2 captured from OTA.
    Make a post here if you like with some info
    what they are etc and we can move to a suitable location easy
      I just got another firmware for the uplus/vplus it is the android upgrade from 6.01 to 7.1.2.. could you please set it so these firmwares could get noticed and maybe somebody will start fiddlling with them and maybe build a rom. i am getting absolutely nowhere except that i keep finding firmware.
      ALSO: have firmware from oem boxes made by zoomtak from past and present that were sold under the brands streamsmart, thorstream, and a bunch of brands, the one thing that is common abiut them is they are all zoomtak.
        anyone have a zip version of 7.1.2 nougat, so i can flash my ebox t8 v with it via twrp, basically the same box.
          have you found anybody that can mod this box?
          the uplus firmware is close to the t8 V. the burning tooll is the way
            no sorry only for the ebox t8 v s912 over at xda poison rom 4.1, its the same box basically so i cannot see what it would not work.
              Hello I have the original zoomtak vplus on Android 6. Does anyone has the Rom for Android 7.1? Thanks
                hi Zoomtak Upro remains in the opening here img I installed again the same time did not change upro zoom in the article stays on tv
                img 7.1.2 on What else do we thank
                  You need to repeat that, not making sense to me.
                    while the device was zoomtak from the TV
                    I installed the software here the same thing is not changing the menu remains
                    what else can i do
                      zoomtak upro trying to install VORKE-Z6 img
                      no problem but its ZoomtakUPRO fingerprint = Amlogic / q201_3G / q201_3G: 6.0.1 / MHC19J / 20170606: userdebug / test-keys
                      When I install the device stays in the opening zoomtak article
                        that is marshmallow, maybe upgrade to 7.01
                          Hi folks,
                          I have a Zoomtak Uplus which is S912, 2gb/16gb, with sata, 4k hdmi etc aluminium box. It is running 6.0.1 and would like to update to 7.1.2.
                          So I am looking at the last like of the first post here. It gives me a zip file zoomtakvplusuplus.nougat.am.20181105.v8.3.4_201811 05.zip
                          My question is how to install/flash it on to the device. The Amlogic USB burner tool takes only .img file.
                          How to flash the zip?
                          Please help.
                          Thanks in advance.
