Request for Help. Mecool M8S Pro 3/32 GB
    Recently I bought a Mecool M8S Pro 3GB DDR4 and 32GB box.
    I would like to install custom rom on it but, could not do it as there is no reset button (I opened the box and checked for it inside).
    I highly appreciate if anyone could let me know the procedure, if any, to install a custom rom without using reset button.
    Regards,
    tdp
    Hope this will help you: http://4pda.ru/forum/index.php?s=&sh...ost&p=67865686
      The way I solved is, Amlogic has an app on the play store (https://play.google.com/store/apps/d...jcts.amltester), which allows you to boot into recovery.
        Yes, but what if you can't enter in Android (this happens), or if you want to brush the device by the USB Burning tool. Connecting the two terminals acts like reset button.
