Voyo Q101 4G phablet Help Please
Hi i bought this tablet 2 weeks ago i updated the firmware with this 1 http://en.myvoyo.com/xiazai/Win%20Pad/VOYO_Q101/down/ after doig the update the tablet is stuck in boot loop ive tried a few firmwares i found on google with no luck .gearbest wont help me fix the issue and i have emailed voyo twice no reply.. ive read that there are 2 versions of the screen a samsung or hawai dont know which 1 i have? can someone please help me get the correct firmware for my tablet please i have opened the tablet up because the power button got stuck so i took some photos .You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosTags: None
Originally posted by DaMeZ View PostHi i bought this tablet 2 weeks ago i updated the firmware with this 1 http://en.myvoyo.com/xiazai/Win%20Pad/VOYO_Q101/down/ after doig the update the tablet is stuck in boot loop ive tried a few firmwares i found on google with no luck .gearbest wont help me fix the issue and i have emailed voyo twice no reply.. ive read that there are 2 versions of the screen a samsung or hawai dont know which 1 i have? can someone please help me get the correct firmware for my tablet please i have opened the tablet up because the power button got stuck so i took some photos .
did you read the Thread on XDA about your Device ??? ,
maybe you can find something there .
It looks like your Device and the Teclast 98 are the same ,
same with my Cube T7 not really good supported Devices .
good luck / greetings / gefattern
My friend won't let me put twrp just incase it stuffs up . So I'm still trying to find a way to backup if I can get it working I'll post here straight away . Or if someone can post a twrp backup for us would be great. I was able to get twrp working on my stuffed tablet.. 6924266912577 that's the barcode I have on the box..
Originally posted by joaoluizt View PostExact same problem here. Boot loop + glitches. Same Voyo Tablet from Gearbest 20171118579. Any news?
Originally posted by joaoluizt View PostThanks
Hello! I have the best news about our VOYO Q101. And again, and again: very bad software, and no hardware problems:
1. I managed port 3 ROM (dotOS: and light version, very light, LineageOS and AOSPExtended). All: 7.1.2
2. A problem with GPS (after work 4 months!): .... FusedLocation .... incredibly better after working with assembly files ... because I don't have a source for high-level programming (Java ). Surprisingly, the location ?fusion? works worse than using clean, unprocessed GPS. I will try to remove the network location + the Bluetooth
3 location . The problem with the battery has been resolved. Best experience: on dotOS. Linear Discharge
Problems:
- just a camera (on all versions). I will try to solve this problem.
Stay up to date!
Ps. I will publish only full working ROM. Therefore, having solved (I hope) problems with the camera, I will share with you my work.
PS2. Porting ROMs are also Chinese devices, so anything is possible ... But better software architecture.
Let's hope it won't take 2 long to release ..
Originally posted by joaoluizt View PostI will try to portCyanogenmod or other rom to voyo q101, just need the rom from voyo q101 serial 20171118579.
There are currently 3254 users online. 2 members and 3252 guests.
