Based version: GT1_705NO_ /70x...........(USB can be flexible as you know)
Android Version: 7.1.2
Fits for : standrad/ultimate 2G+16G/2G+32G/3G+32G G912/S912(QCA9377)
USB burning tool :
https://beelink-my.sharepoint.co ... 4JInsGgzNYvz5qnW-9c (2.0.5)
https://beelink-my.sharepoint.co ... uaAYAcoK-dm4kmsvCs4 (2.0.9)
USB zip :
https://beelink-my.sharepoint.com/:u:/g/personal/firmwareservice_beelink_onmicrosoft_com/EUW-I25ZYdBDt_TgzwClPX0BI4cXVyJf5scV6dipq-8V1w?e=eqhBne
SD card :
https://beelink-my.sharepoint.com/:f:/g/personal/firmwareservice_beelink_onmicrosoft_com/EvoC_Fw67-5OimK5athX8zsBFKXy6h0LN-EfXrhB1dLftw?e=UNoPon
Updating tutorial:
https://www.youtube.com/watch?v=m8chkgcfcwQ (USB)
Improvement:
1. The system has been improved already .
2. You can see a new Bee Fiiles manager .
3. Rgb has been added to this firmware .
4. You can get into the recover mode by pressing the reset button .
5. You can get the permissions for unroot firmware now .
6. The problem that the pictures are enlarged randomly has been solved .
7. You can get into the landscape mode freely .
8. The shut down popup has been removed for popular demands .
9. The SuperSu can't be installed for safe use .
10.We updated the FOTA apk for you .
11.The thrid - party apps can get the read permessions now .
12.The output frame rate can be compatible with the video samples now .
Pay attention to :
1. A912/AX12-----AP6255 G912/S912-----QCA9377
2. You need to use the firmware which starts from the 70X D0 since a new barcode has been use to the GT1 , i will post it in the next thread . just like this series number shows :
" GT1 3G+32G D0 version : A706D0SBH70001 32G "
You may cause the blue screen / pink screen problems if you get something wrong , so you can as me for help if meet some problems about it .
3.Some links before the 707 NO have been deleted to avoid the updating errors , you can turn me for help if it's necessary .
4.You can only update the firmware from system 6.0 (301MO/101MO.......) to system 7.0 (701NO......)by USB updating , on the other hand , you can update the firmware from system 6.0 (301MO......)to system 6.0 (312MO,313MO) by SD card or USB updating .
5.Standard edition (2G+16G/2G+32G) : before ( system 6.0 ) <101 MO ( system 6.0 ) < ......113 MO ( system 6.0 ) < ...... updating (system 6.0)
Ultimate edition ( 3G+32G ) :
before ( system 6.0 ) <301MO ( system6.0 ) < ......313MO ( system6.0 ) < ...... updating (system 6.0)
Standard edition / ultimate edition :
701 NO ( system 7.1 ) < 702 NO ( system 7.1 ) < ...... updating (system 7.1 )
