Current version: GT1_708NO_ Based version: GT1_706NO_ /70x...........(USB can be flexible as you know) Android Version: 7.1.2 Fits for : standrad/ultimate 2G+16G/2G+32G/3G+32G A912/AX12(AP6255) USB burning tool : https://beelink-my.sharepoint.co ... 4JInsGgzNYvz5qnW-9c (2.0.5) https://beelink-my.sharepoint.co ... uaAYAcoK-dm4kmsvCs4 (2.0.9) USB zip : https://beelink-my.sharepoint.com/:u:/g/personal/firmwareservice_beelink_onmicrosoft_com/EW4Yt9hf5eBDhcdWCl3kQkMB79kiPAgBWiA6-m5jUc8L8A?e=WoHlha SD card : https://beelink-my.sharepoint.com/:f:/g/personal/firmwareservice_beelink_onmicrosoft_com/EsDbO4P-7ElFqAV7eIYArPsBtHK3kUCCvsgA8sdL3MDcdg?e=q2kf9g Updating tutorial: https://www.youtube.com/watch?v=m8chkgcfcwQ (USB) Improvement: 1. The system has been improved already . 2. You can see a new Bee Fiiles manager . 3. Rgb has been added to this firmware . 4. You can get into the recover mode by pressing the reset button . 5. You can get the permissions for unroot firmware now . 6. The problem that the pictures are enlarged randomly has been solved . 7. You can get into the landscape mode freely . 8. The shut down popup has been removed for popular demands . 9. The SuperSu can't be installed for safe use . 10.We updated the FOTA apk for you . 11.The thrid - party apps can get the read permessions now . 12.The output frame rate can be compatible with the video samples now . Pay attention to : 1. A912/AX12-----AP6255 G912/S912-----QCA9377 2. You need to use the firmware which starts from the 70X D0 since a new barcode has been use to the GT1 , i will post it in the next thread . just like this series number shows : " GT1 3G+32G D0 version : A706D0SBH70001 32G " You may cause the blue screen / pink screen problems if you get something wrong , so you can as me for help if meet some problems about it . 3.Some links before the 707 NO have been deleted to avoid the updating errors , you can turn me for help if it's necessary . 4.You can only update the firmware from system 6.0 (301MO/101MO.......) to system 7.0 (701NO......)by USB updating , on the other hand , you can update the firmware from system 6.0 (301MO......)to system 6.0 (312MO,313MO) by SD card or USB updating . 5.Standard edition (2G+16G/2G+32G) : before ( system 6.0 ) <101 MO ( system 6.0 ) < ......113 MO ( system 6.0 ) < ...... updating (system 6.0) Ultimate edition ( 3G+32G ) : before ( system 6.0 ) <301MO ( system6.0 ) < ......313MO ( system6.0 ) < ...... updating (system 6.0) Standard edition / ultimate edition : 701 NO ( system 7.1 ) < 702 NO ( system 7.1 ) < ...... updating (system 7.1 ) |
GT1 708NO standrad/ultimate 2G+16G/2G+32G/3G+32G A912/AX12(AP6255)
Tags: None
Originally posted by lilou61 View Posthello, my Beelink GT1 Ultimate Android TV Box 6.0 BT 4.0 Amlogic S912 3G + 32G Media Player is stuck on a green screen, I tried several ROOM & Firware by booting with 1 SD card but no result. Please tell me what to do.
Thank you.
https://forum.freaktab.com/forum/tv-...both-6255-9377
There are currently 2229 users online. 6 members and 2223 guests.
