Current version : GT1_708D0_AP6255 Based version : GT1_707D0_AP6255/GT1_706D0_AP6255 Android Version: 7.1.2 Fits for : ultimate / 3G+32G A......D0.......(AP6255) ,for example : " A706D0SBH70001 32G " there is only one wifi chip for D0 , it's AP6255 . USB burning tool : 1) https://beelink-my.sharepoint.co ... fee834014e0a0c900b8 (2.0.5) 2) https://beelink-my.sharepoint.co ... ed0a5d0d45a2b893657 (2.0.9) USB zip : https://beelink-my.sharepoint.com/:u:/g/personal/firmwareservice_beelink_onmicrosoft_com/EZJK8eI_qvBPmXSsy5MmlzgB9gKn1PFJkA3auFzCpBxIdg?e=e qKfAn SD card zip : https://beelink-my.sharepoint.com/:f:/g/personal/firmwareservice_beelink_onmicrosoft_com/Enrv_Hrz2UBMt8VzvMM_7TEBHfHEV8Vnx80ei8b-BlYs8Q?e=fsFGAJ Updating tutorial : 1.https://www.youtube.com/watch?v=m8chkgcfcwQ (USB) 2.https://www.youtube.com/watch?v=saZWCyXVETQ&t=333s (SD card ) Improvement : 1. The system has been improved already . 2. You can see a new Bee Fiiles manager . 3. Rgb has been added to this firmware . 4. You can get into the recover mode by pressing the reset button . 5. You can get the permissions for unroot firmware now . 6. The problem that the pictures are enlarged randomly has been solved . 7. You can get into the landscape mode freely . 8. The shut down popup has been removed for popular demands . 9. The SuperSu can't be installed for safe use . 10.We updated the FOTA apk for you . 11.The thrid - party apps can get the read permessions now . 12.The output frame rate can be compatible with the video samples now . Pay attention to : 1. A912/AX12-----AP6255 G912/S912-----QCA9377 A706D0SBH70001 32G---------D0 AP6255 2. You need to use the firmware which starts from the 70X D0 since a new barcode has been use to the GT1 , i will post it in the next thread . just like this series number shows : " GT1 3G+32G D0 version : A706D0SBH70001 32G " You may cause the blue screen / pink screen problems if you get something wrong , so you can as me for help if meet some problems about it . 3.Some links before the 707 NO have been deleted to avoid the updating errors , you can turn me for help if it's necessary . 4.You can only update the firmware from system 6.0 (301MO/101MO.......) to system 7.0 (701NO......)by USB updating , on the other hand , you can update the firmware from system 6.0 (301MO......)to system 6.0 (312MO,313MO) by SD card or USB updating . 5.Standard edition (2G+16G/2G+32G) : before ( system 6.0 ) <101 MO ( system 6.0 ) < ......113 MO ( system 6.0 ) < ...... updating (system 6.0) Ultimate edition ( 3G+32G ) : before ( system 6.0 ) <301MO ( system6.0 ) < ......313MO ( system6.0 ) < ...... updating (system 6.0) Standard edition / ultimate edition : 701 NO ( system 7.1 ) < 702 NO ( system 7.1 ) < ...... updating (system 7.1 ) |
GT1 708D0 ultimate/3G+32G A......D0 (AP6255)
Tags: None
hello!
i have GT1 with s/n: A912BKBG60504 and as instructed I am trying to install ROM attached to this topic: GT1_708D0_AP6255 from SD card
i am getting an error:
E3004: This package is for "q201" devices; this is a "q201-9377".
what am I doing wrong? Can u please help me upgrading my device? It keeps freezing every 5 minutes
708 FW has wifi issues. If you reboot the device, it won't connect to wifi, and when it does, it keeps on disconnecting every second. Please fix this as it's very annoying...
I think you guys need to hire better tech guys as your hardware's good but software's shit... fire the current team, they are giving you bad name...
There are currently 2657 users online. 0 members and 2657 guests.
