Firmware for H96 pro dongle with ethernet drivers enabled?
    The shitty 2.4ghz wifi on this dongle makes it unusable. Is there a compatible firmware that allows me to use a USB to ethernet adapter? Apparently the stock kernel has ethernet drivers turned off. I would like to be able to keep Bluetooth support. Thanks
