Tanix TX28 TV Box - RK3328 Android 7.1 4GB RAM + 32GB ROM 2.4G + 5G WiFi BT4.1 100Mbps USB3.0
    Specification
    Brand: Tanix
    Model: TX28
    Type: TV Box
    GPU: Mali-450MP2
    System: Android 7.1
    CPU: RK3328
    Core: 1.5GHz,Cortex A53,Octa Core
    RAM: 4G
    RAM Type: LPDDR3
    ROM: 32G
    Decoder Format: H.264,HD AVC/VC-1,HD MPEG1/2/4,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
    Video format: 3GP,AVI,DIVX,FLV,H.264,H.265,M4V,MKV,MP2,MPEG,MPEG-1,MVS,REAL MEDIA,RM,VC-1,VP9-10 Profile-2,WMV
    Audio format: AAC,AMR,AMR-WB,EAAC+,HD,MKA,MP2,MPEG,RA,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth 4.1
    Power Supply: Charge Adapter
    Interface: DC 5V,HDMI,Reset Port,SIM card slot,Standard SIM card slot,USB 3.1 Type-C,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: DLNA
    RJ45 Port Speed: 100M
    Power Type: External Power Adapter Mode
    Power Input Vol: 5V
    Product weight: 0.3500 kg
    Package weight: 0.5000 kg
    Product size (L x W x H): 10.50 x 10.50 x 2.50 cm / 4.13 x 4.13 x 0.98 inches
    Package size (L x W x H): 15.50 x 13.70 x 8.00 cm / 6.1 x 5.39 x 3.15 inches
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English User Manual
    Gearbest
    Hi tЯeboЯ, will you be doing any teardown or review of the box? Am interested on how this will compare to the Alfawise Z28 Pro you've reviewed. That was one sweet box with 2T2R WiFi chip, but lacking in general workmanship. Tanix usually makes excellent product, and their box is priced 50% more expensive so quite interested in build quality.
      Thanks to gearbest we can have a close look today at the
      The Box:
      Contents of the Box:
      The Guided Look around
      Front:
      Ports on the Back
      Side WiFi and USB 3 Port
      Tf Card slot:
      Remove the Base an upside unit:
      Otherside of PCB not much here:
      Close up of the Bits
      A Green Display...
      A clean look, neat layout...more as it happens
      Gearbest
        Originally posted by trebor View Post
        Sweet, thanks tReboR, waiting for the detailed review. I don't think I've ever seen a Cdtech W-Fi chip before.
          Yes a bit different another clone maybe, working ok 5g and BT so far
          Box working ok more later
          China Dragon Technology
          yet to find 201023
            Pretty Good looking Unit I find, and I feel performance on par with most others in this series
            Temps 60~70c pending on what's going on at the time all relative really.
            No Upper or Lower bars, Root access with no SU Installed.
            Setup Good and Easy, Google account, installed apps and testers
            I found Wifi Speed looking dood this CDTECH chip may have the goods
            Detected and Used BT speaker all good and remote OK for what it has to offer.
            Not too shabby at all
            Lets have a look see.
            UI and Installed Apps:
            System Information:
            Ram and Storage Truth
            CPU-Z
            Monitor
            DRM or lack of
            Root acsess No SU
            Geekbench CPU More > http://browser.geekbench.com/v4/cpu/8150294
            Geekbench Compute
            YouTube looking good
            FileExplorer
            A1 SDBench looking OK
            Gearbest
              Shockingly bad stock ROM.
              ​​​​Random crashes and reboots. Google Play will only allow me to download half of my apps - for example I can't download MX Player (no internet connection message) but can download MX Player Pro! Security patch April 2017.
                Same problem here won't let me download hardly any apps from play store.
                  Just received my TX28 and I cannot download many apps either. Any ideas for a work around?
                    Beta download here
                    http://www.tanix-box.com/download-vi...date-firmware/
                    The instructions say to use installed Update & Recovery app. One slight snag: it doesn't exist!
                    Edit: rename to update.zip; copy to SD card; and install through recovery.
                      Where I find a .img image file for recover my TX28?
                        [QUOTE=Edit: rename to update.zip; copy to SD card, and install through recovery. [/QUOTE]
                        A touch of genius, now works!
                          Originally posted by glaven View Post
                          Beta download here
                          After update above still the same problems and no answer from support, several attempts to contact with no reply was ignored.
                          would never buy another Tanix.
                            Two months later and still beta testing. Ridiculous. I think in future I'll pay a bit more for a decent TV box. I have recently abandoned cheaper android tablets (teclast et al) for a Huawei M5 and the difference is astonishing.
                              Have also given up on tanix and bought an Nvidia shield really worth the price.
