Mecool M8S Pro and Pro-L
    I see that the Pro has DDR4 while Pro-L has DDR3. Other than the difference, what are the differences of the two boxes?
    1. From Gearbest, the Pro support Netflix while the Pro-L supports Netflix-HD. Does this mean that the Pro does not support Netflix-HD?
    2. Which one one is the newer box? Looks to me that the Pro-L is the newer box but it sports the older memory type.
    3. I see the last firmware update of the Pro is 20171030. How about the Pro-L?
    Here is the information on the M8S Pro -L "with the Voice Remote Blue Tooth"
    This version of the -L has DDR3, but it is a OEM Android TV (like google nexus, not the standard Android)
    Comes with Voice Remote which is BlueTooth and IR
    M8S Pro -L with Voice Remote
    Mine was ordered late 2/22/2018 arrived on 3/19/2018
    Kernel 3.14.29 created Monday Feb. 5 11:19:24 2018
    Android 7.1.1 NHG47L
    20180205 111652. V0928
    Supports Widevine L1
    NetFlix plays at 1080
    the specifications above is the latest Offering from MeCool M8S pro -L with Remote/bluetooth/Android tv this is a 912 version 3gb/32gb around 80 dollars us plus/minus
    They also have a MeCool M8S Pro -W with Voice Remote/bluetooth/Android TV this is a 905X version 2gb/16gb at around 41 us dollars plus/minus.
    This was ordered from Bangood.
    Regards
      Regards
      GB (Gearbest) just posted a coupon for $66 USD. Free shipping??? IMHO, the remote is worth $20 USD or more.
      2018/03/21 00:00 ~ 2018/04/17
      Mecool M8S PRO L Smart Bluetooth Voice Control TV Box /3+32G
      $65.99 coupon: GBXL amount: 30
        Hello
        apparently there is a heating problem with this box, or is it simply optimization?
        what is this box really worth?
        I have a beelink gt1, need a more powerful box ...
        thank you
          About Netflix on this box, does it support offline viewing?
