The IP68 waterproof OUKITEL WP5000 gets 73119 antutu score, full specs released
Name:	OUKITEL WP5000smaller.png
    Early this month, OUKITEL announced the rugged smartphone WP5000. As a combin ation of tri-proof features and large battery, WP5000 is much anticipated. OUKITEL plans to bring this WP5000 to market by end of this month or early April. To greet the coming global first presale, OUKITEL is conducting the subscription activity on their official website. While waiting for the final perfect smartphone, we are able to check its full specifications first.
    Video: OUKITEL WP5000 first hands on with antutu test: https://youtu.be/MnZiMmiWOaQ
    From the video, we can see that OUKITEL WP5000 looks comparatively thin and slim, it changed our old image of thick tri-proof smartphones. It supports compass to indicate directions, super power saving mode to save energy in the wild, and Zello-the interphone pre-installed allow you to communicate with your friends with no cellphone bills. The software of WP5000 allows you to answer phone calls by shaking your mobile phone. So even under water, you can receive phone calls. What surprise us is that WP5000 gets an antutu score of 73119, far higher than same spec mobile phones. Are you curious about its full specs? Check it below:
    Processor: MediaTek MT6757CD octa-core 2.5GHz
    OS: Android 7.1.1
    Display:
    Size: 5.7 inch HD+, 1440*720 resolution
    Touch: 5 points multi-touch
    Color: Black, orange, green
    Cameras:
    Primary: Samsung 3P3 16.0MP+5MP, 21MP interpolated, true-tone LED flash light
    Secondary: 8.0MP, 13MP interpolated
    Memory: 6GB RAM+64GB ROM, 128GB expandable
    Network:
    GSM: 850/900/1800/1900MHz;
    WCDMA: 900/2100MHz;
    4G FDD: B1/B3/B7/B8/B20
    SIM card type: 1 nano SIM+1 SD card;2 nano SIM
    Connectivity:
    USB Port: Type-C port
    Ear jack: Type-C port
    WLAN: Support,802.11 a/b/g/n/,Hotspot
    Bluetooth: V4.0
    Sensors:
    Press fingerprint sensor/ Gravity sensor/ proximity sensor/ Light sensor/ gyroscope sensor/ geomagnetic sensor/notification LED
    OTG: Yes
    OTA: support
    FM Radio: support
    Dimensions: 168.8*81.9*13.9mm,weight:276.5g
    Battery: 5,000mAh, 9V/2A charger
    OUKITEL WP5000 features 18:9 long display, 5000mAh large battery, 6GB RAM and 64GB ROM large flash memory, 16MP great camera,and a rugged body. It will get 3 colors: black, orange, and green. By subscription on OUKITEL official website, you will be able to get a lower price than presale flash sale price. Interested? Check details here: http://www.oukitel.com/activity/activity-42.html
    http://oukitel.com/
