[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on tillaz87 [ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Std+Ultimate)
To all those Vorke Z6 plus owners: I wrote an article here about how to unbrick - and also how to update --- however, my box also keeps crashing every 5 minutes. I think the hardware is the problem, not the software / firmware. It's dodgy components - something not right - probably a cheap resister or something!
Anyway, if you find it useful, good luck! Now I am looking for recommendations on a good solid box.
Originally posted by Alianato View PostThis topic is about adapting the [ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate) made by tillaz87 to work on the Tanix TX9 Pro / Vorke Z6 Plus
(pictures attached).
Does anyone knows if this firmware will work on this box?
Tiago
Hello every one. i need some help. i have flash this rom via USB Burning Tool. after that, i flash stock firmware TX9pro-20180205. now i lost my serial number. it show Unknown on info. i have try flash some other stock firmware version but nothing help. So,How can i fix this? help me please. So sorry for my bad english.
Originally posted by zelder View PostI don't understand what firmware really means on a ATV box. Is the firmware some sort of SW upgrade to Vorkes Android? Or am I wrong? If I use this custom ATV version, do I need to install the firmware?
concerning dual boot you can do it. there is an app on play store to boot on libreelec. Your devise need to be rooted for lauching the dual boot.
I recommand to you to use Coreelec instead of Libreelec.
Originally posted by Marcus95 View PostHi,
From my side, the Rom is working very well !! I installed directly 10.7 version.
Two problem i noticed :
- LED zip not working for the hour (i have sometime 6F. Issue with time setting)
- chromecast not working
- When the devise is in stand by mode, the devise is hot. So I need to shutdown the devise every time.
- still having freeze on video playing with all player (Kodi, vlc) => need to use CoreElec
There are currently 2153 users online. 1 members and 2152 guests.
