M96X PLUS TV BOX - Amlogic S912 Android 7.1 2/16GB ROM Dual WiFi Gig Lan BT4.0
    Click image for larger version  Name:	20180320133858_77513.jpg Views:	1 Size:	64.8 KB ID:	715531
    Spec's as found
    GPU: ARM Mali-T820MP3
    System: Android 7.1
    CPU: Amlogic S912
    Core: 2.0GHz,Cortex A53,Octa Core
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G ROM
    Max. Extended Capacity: 128G
    Decoder Format: H.264,HD AVC/VC-1,HD MPEG1/2/4,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
    Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B,WMV
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,HDMI,RJ45,SD Card Slot,SPDIF,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: Others
    External Subtitle Supported: Yes
    RJ45 Port Speed: 1000M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Power Input Vol: 5V
    Product weight: 0.5000 kg
    Package weight: 0.6800 kg
    Product size (L x W x H): 11.40 x 11.40 x 2.48 cm / 4.49 x 4.49 x 0.98 inches
    Package size (L x W x H): 19.00 x 19.00 x 5.30 cm / 7.48 x 7.48 x 2.09 inches
    Package Contents: 1 x TV Box, 1 x USB Cable, 1 x Power Adapter, 1 x Remote Control, 1 x English User Manual
    Gearbest
    M96X Plus firmware
      Recently got one of these. Problem with streaming movies - they freeze. The box does not freeze, only the movie playback. The only solution is to click the back button, select it again and then select resume (if available) but then another 30 minutes or so into the movie it happens again. The average length movie will freeze up to 4 times during viewing. Most annoying. Not good at all. Does anyone else experience this?
      Cant obtain factory reset or recovery no matter what. It just sits there displaying first boot screen and goes no further.
      This has to be one of the worst boxes Ive ever had. Its got so much going for it under the hood. The plonkers that released this box without proper testing all want shooting.
        M96X PLUS:https://mega.nz/#!B6JDjAwD!wTo7cvOHL...1T2i5Jyurg0TPA
          firmware update
            Hi mate, I cant thank you enough for this.
            Installed first go using USB_Burning_Tool.
            Genuine Root.
            Managed to get temporary TWRP using S905_TWRP3_ViT.zip so now I can back up and access recovery.
            Just need a bit of time now to see if picture playback has stopped freezing.
            Many thanks once again, the box was almost binned.
            Just tried playing some 4k from USB stick, its perfectly smooth.
              Thanks to Gearbest we can have a close look at the
              Spec's as found:
              System: Android 7.1
              CPU: Amlogic S912
              RAM: 2G
              RAM Type: DDR3
              ROM: 16G ROM
              5G WiFi: Yes
              HDMI Version: 2.0
              System Bit: 64Bit
              Power Input Vol: 5V
              The Box:
              Contents
              Bit of a look around: Rear Ports
              Side Ports:
              Remove base:
              Remove PCB: WiFi Antenna on Lid
              Close look the Bits:
              Gearbest
                Been awhile since I have had a fiddle with a S912 Box,
                This one a 2/16gb and doing ok
                Temps 50 to ~70c when pushed
                Set up of Google, Wifi etc all good updates of apps and Installed testers Ok.
                Upper and Lower Bars present with Root access and SU installed.
                Fairly standard UI and the usual Batch of Apps and Bits installed, No boot logo/loader just the standard s912 badge
                Working good no problems, BT Speaker tested all good and the remote well as good as it can be.
                Let's have a look at what we have.
                UI Installed Apps: upper and lower
                Root access
                System Info:
                Ram and Storage Truth
                CPU-Z
                Geekbench CPU: > Full Details
                http://browser.geekbench.com/v4/cpu/8159964
                Geekbench Compute:
                DRM L3
                Monitor
                A1 SDBench
                  I have problem with m96x PLUS with up volume and down volume after update 03 01 2018 .Any idea about that
                    No steps with volume
                      Root access
                      System Info:
                      CPU-Z
                      Geekbench Compute:
                      DRM L3
                      Monitor
                      A1 SDBench
                      Please I need this firmware 04 01 2018
                        I have not tested this firmware but got this link from the answer section of the product page of Gearbest.com https://www.gearbest.com/tv-box/pp_1...ml?wid=1433363
                        Firmware link https://pan.baidu.com/s/1kK55rhWZi4fR9NB1-p7J_g
                        Password: q6dr
                        I want to buy this device and install Libreelec in it.If someone has installed librelec and everything works fine (LAN,WIFI,Bluetooth) please reply.
                          Thank you. I tried this box. It is very good but sometimes the heat raise to 70 or 80
                            It seems m96x brand has very poor heat sink. It will be better if you can install a heatsink and fan after removing the factory installed cheap quality heatsink. i am concerned with the noname wifi chip HS2734A V15628 they have included with an otherwise ok hardware. If possible can you install libreelec with kodi on a sd card and check if everything works?
                              I am sorry because l don't have sd card but I will try to do that with usb flash.
