TWRP 3.0.2-Nougat for T95U-Pro here: https://mega.nz/#!poAmXTTL!geVautNHm...N95aHqTrGCqRVE
Sunvell T95U-Pro 2Gb/16Gb stock (rooted) Android 7.1.1 ROM here: https://mega.nz/#!v5RHwLhB!2crBWXomk...KrAYEApgF03Ikg
TWRP 3.0.2 works perfectly on Sunvell T95U-Pro 2Gb/16Gb running stock (rooted) Android 7.1.1 booted onto a 32Gb SanDisk UHS-1 TF (FAT-32).
Magisk 16 successfully installed (Un-SU flashed first). Important, use TWRP to flash Magisk the first time! For subsequent Magisk updates, you should be OK using the direct method from within the Magisk Manager app.
Both WiFi and BT are working fine (board ref. q201_6255).
1080p playback on Kodi streamed over 1Gbps LAN is perfect, tested with 2018 Jumanji WTTJ rip.
