Firefly RK3288 Plus Quad Core Cortex-A17 Processors Development Board 2GB/32GB Dual WIFI HDMI 2.0 BT Gig LAN
    Supports Android 4.4 and Ubuntu dual system. It can be used for office, study, games, entertainment, server, software development, and intelligent embedded equipment.
    2.4GHz/5.0GHz WiFi
    Support 2.4 GHz/5 GHz Dual-Band WiFi, as well as Bluetooth 4.0, has a strong network extension and transmission capacity.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second. It can improve the Internet speed and the performance to a great extent.
    RK3288 Clocked at 1.8 Ghz Max
    CPU: RK3288 Cortex-A17 quad core up to 1.8GHz
    GPU: Mali-T764 GPU with support for OpenGL ES 1.1/2.0 /3.0, OpenVG1.1, OpenCL, Directx11
    DDR3 2GB RAM + eMMC 32GB ROM
    It boasts DDR3 2GB RAM, and eMMC 32GB Flash, advantageous in performance, security and reliability, ascribing to the eMMC memory,ultimately delivering a richer end-user experience.
    4Kx2K@60Hz Video Resolution
    HDMI 2.0 supports up to 18Gbps Data transmission rate and up to 4Kx2K@60Hz video resolution.
    Geekbuying
    Hi ,
    the "header" says RK3288 , is it not RK3328 ??? , if not the post must moved to RK3288 .
    greetings / gefattern
    • trebor
      trebor commented
      Editing a comment
      No idea its in 3288
