Dimension | 96*96*17mm | |
Weight | Only Device kg | |
With Accessories kg | ||
CPU | Quad-core 64-bit ARM Cortex A53 | |
GPU | High-performance multi-core GPU Mali T720MP2 | |
Graphics | H265/HEVC Main/Main10 [email protected] High-tier ;4K@60fps, up to 6Kx4K@30fps • H264/AVC BP/MP/[email protected], MVC, 4K@30fps • VP9,Profile 0/2, 4K@30fps • VP6/VP8, 1080P@60fps • MPEG1/MPEG2 SP@ML, MP@HL, 1080P@60fps • MPEG4 SP@level 0~3, ASP@level 0~5, GMC, short header format, 1080P@60fps • AVS+/AVS JIZHUN profile@level 6.0, 1080P@60fps • VC-1 SP@ML, MP@HL, AP@level 0~3, 1080P@60fps • Supports Frame Buffer Compression(FBC) • Output pixel format configurable,YUV420/YV12/NV12/ |
Display | HDMI 2.0a | |
Memory | 2GB/3GB | |
Storage | 16GB/32GB | |
Extended USB Mechanical Hard Disk 2.5/3.5inch 4TB Storage | ||
Extended Storage TF card | ||
Network | WIFI IEEE 802.11 b/g/n/ac 2.4G 5.8G | |
Lan 1000M | ||
BT4.1 | ||
Interface | SPDIF | 1* Port |
USB2.0 | 1* USB Port | |
HDMI | 1*HD A Type Port | |
RJ45 | 1*RJ45 | |
USB3.0 | 1* Port | |
TF Card | 1* Micro SD card | |
DC-in | 1*DC in Port | |
Remote control | Standard Infrared Remote(IR) | |
Extended WIFI2.4G Remote | ||
Power LED | 1* power LED | |
Upgrade OS | 1* Upgrade button | |
Software OS | Android 7.1 | |
Adapter | INPUT AC:100-240V~50/60Hz OUTPUT DC:5V 2000mA | |
Work Environment | -10°C--45°C,30%--90% Humidity | |
Storage Environment | -20°C--60°C,10%--90% Humidity | |
Accessories | 1*Adapter 5v 2A | |
1*HDMI Cable 80CM | ||
1*Manual |
GS1 TV BOX Product Specification
Tags: None
There are currently 1518 users online. 0 members and 1518 guests.
