GT1 708D0 ultimate/3G+32G A......D0 (AP6255/KM6335)
    Current version : GT1_708D0_AP6255(KM6335)
    Based version : GT1_707D0_AP6255(KM6335)/.........
    Android Version: 7.1.2
    Fits for : ultimate / 3G+32G A......D0.......(AP6255) ,for example : " A706D0SBH70001 32G " there is only one wifi chip for D0 , it's AP6255 .
    USB burning tool :
    1) https://beelink-my.sharepoint.co ... fee834014e0a0c900b8 (2.0.5)
    2) https://beelink-my.sharepoint.co ... ed0a5d0d45a2b893657 (2.0.9)
    USB zip :
    https://beelink-my.sharepoint.com/:u...BxIdg?e=x7UFXb
    SD card zip :
    https://beelink-my.sharepoint.com/:f...lYs8Q?e=q3MQAO
    Updating tutorial :
    1.https://www.youtube.com/watch?v=m8chkgcfcwQ (USB)
    2.https://www.youtube.com/watch?v=saZWCyXVETQ&t=333s (SD card )
    Improvement :
    1. The system has been improved already .
    2. You can see a new Bee Fiiles manager .
    3. Rgb has been added to this firmware .
    4. You can get into the recover mode by pressing the reset button .
    5. You can get the permissions for unroot firmware now .
    6. The problem that the pictures are enlarged randomly has been solved .
    7. You can get into the landscape mode freely .
    8. The shut down popup has been removed for popular demands .
    9. The SuperSu can't be installed for safe use .
    10.We updated the FOTA apk for you .
    11.The thrid - party apps can get the read permessions now .
    12.The output frame rate can be compatible with the video samples now .
    Pay attention to :
    1. A912/AX12-----AP6255 G912/S912-----QCA9377 A706D0SBH70001 32G---------D0 AP6255
    2. You need to use the firmware which starts from the 70X D0 since a new barcode has been use to the GT1 , i will post it in the
    next thread . just like this series number shows :
    " GT1 3G+32G D0 version : A706D0SBH70001 32G "
    You may cause the blue screen / pink screen problems if you get something wrong , so you can as me for help if meet some
    problems about it .
    3.Some links before the 707 NO have been deleted to avoid the updating errors , you can turn me for help if it's necessary .
    4.You can only update the firmware from system 6.0 (301MO/101MO.......) to system 7.0 (701NO......)by USB updating , on the
    other hand , you can update the firmware from system 6.0 (301MO......)to system 6.0 (312MO,313MO) by SD card or USB
    updating .
    5.Standard edition (2G+16G/2G+32G) : before ( system 6.0 ) <101 MO ( system 6.0 ) < ......113 MO ( system 6.0 ) < ......
    updating (system 6.0)
    Ultimate edition ( 3G+32G ) :
    before ( system 6.0 ) <301MO ( system6.0 ) < ......313MO ( system6.0 ) < ...... updating (system 6.0)
    Standard edition / ultimate edition :
    701 NO ( system 7.1 ) < 702 NO ( system 7.1 ) < ...... updating (system 7.1 )
    Movies that play flawlessly on my phone buffer like nobody's business your software.
      I have a 706DO GT1 Ultimate and as reported on other threads these have fake ram. This is a "pack of lies" rom it reports 3GB when it only has 2GB. This causes apps to stop randomly.
      You can test this by installing Fill Ram from the playstore. When you run it the memory won't fill past 62% on a box with fake ram before closing and it doesn't even flag that memory is low.
      I also have a non ultimate GT1 with 2GB. This fills to 93%, flags ram is low and keeps running which is what should happen.
      If I put a shillingworth based rom on the 706DO box it reports the ram correctly at 2GB.
      Why does your rom lie Beelink?
      There are so many versions of the GT1 ultimate,, some with fake ram, some with dodgy GPUs. I will never buy a beelink box again!
