Alfawise T1 Mini PC Gemini Lake N4100 Supports Windows 10 4GB + 64GB ROM 802.11/AC Gig lan
    Click image for larger version  Name:	20180329105655_55239.jpg Views:	1 Size:	99.4 KB ID:	717232
    Brand: Alfawise
    Model: T1
    Type: Mini PC
    System: Linux,Windows 10,Windows 8
    CPU: Intel HD Graphics 400
    Core: 2.4GHz,Quad Core
    GPU: Intel HD Graphics 620
    RAM: 4G
    RAM Type: DDR4
    ROM: 64G
    Maximum External Hard Drives Capacity: 2TB
    Decoder Format: H.264,H.265,HD MPEG4
    Video format: AVI,DAT,ISO,MKV,MP4,MPEG1,MPEG2,MPEG4,RM,WMV
    Audio format: AAC,APE,FLAC,MP3,OGG,RM,WAV
    Photo Format: GIF,JPEG,JPG,PNG
    Support 5.1 Surround Sound Output: No
    5G WiFi:
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: 3.5mm Audio,DC-in,HDMI,Mic,RJ45,TF card,Type-C,USB3.0,VGA
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: Others
    Power Consumption.: 36W
    RJ45 Port Speed: 1000M
    System Bit: 64Bit
    WiFi Chip: Intel3165
    Power Type: External Power Adapter Mode
    Product weight: 0.4070 kg
    Package weight: 1.2500 kg
    Product size (L x W x H): 16.00 x 13.45 x 3.20 cm / 6.3 x 5.3 x 1.26 inches
    Package size (L x W x H): 17.20 x 14.50 x 9.20 cm / 6.77 x 5.71 x 3.62 inches
    Package Contents: 1 x Mini PC, 1 x Power Adapter, 1 x HDMI ( 80mm ), 1 x HDMI ( 20mm ), 1 x PC Holder, 1 x English User Manual
    Gearbest
    Greetings Trebor.
    Nice to see Gemini Lake finally appearing in TV boxes. Hoep you'll be reviewing more of these.
    As for the Alfawise T1, here are some questions:
    1. Fanless?
    2. Windoes OS included?
    3. Sata3 port?
    4. M.2 SSD?
    5. RAM: 1 or 2 banks? Upgradale?
    6. ROM: Upgradable?
    Many thanks and best regards,
      Thanks to Gearbest today we get to have a closer look at
      Main Features
      Intel GEMINI LAKE Celeron N4100 CPU with 4 cores 4 threads, 4M L2 cache and 2.4GHz frequency
      Intel HD Graphics 600 GPU, 250MHz to 750MHz
      ● Support up to 4K x 2K resolution
      2.4GHz + 5.8GHz WiFi and BT 4.0
      ● 4G DDR4 RAM + 64G ROM
      ● Support 512GB M.2 SSD and 2.5 inch 2TB HHD
      The Box
      What's in the Box, Long and Short HDMI cable Vesa Style of Mount, 12v 1.5A Power Supply.
      Bit of a look around lots of ports
      My Fav Vents
      Space for HDD/SSD
      Small Vesa type Bracket fitted to mount behind TV or anywhere
      Only $169.99,buy Alfawise T1 Mini PC at GearBest Store with free shipping.
        On with some test, and bit of a look around of Windows to follow. on the
        Unit fired up easy, all setup ready to go Activated all good, Hmmm
        Bit of a clean up of things I don't use or need and cut down the start menu size for a start
        First Power Switch ON:
        Little bit of customising, Do a Defender scan, start to install some testing programs.
        In the meantime Windows Update has Started to do its thing,
        Took about ~1.5 hour plus by the time it downloaded and I was doing a defender scan
        With all my mucking around all good in the end, and on the latest I think or close from MS$..
        There was one more minor update.
        The Update left about 30GB of the Previous windows on the Hard disk, quick clean and now 20GB used,
        I find it pretty save to remove the Normal Updatess but if you do the Microsoft Insiders, Lease previous Windows
        More room now to make Windows a Happy Chappy
        Running Just the Stock supplied version of Windows no extra HDD etc and will see how it all goes.
        I found WiFi and Ethernet all good and speeds good, ( it works)
        Setup etc all smooth no problems really like most of these Windows Boxes today, windows does take care of most.
        Not a lot see in the Bios as yet
        Bios
        Booted Linux MInt Easy from USB, Sound WIfi etc all looking good..
        Linux Mint
        The Alfawise T1 is moving along nicely, all good with Netflix, Apps etc, no DRM monkey business here.
        for its CPU, Ram Size fixed at 4/64GB cant add but should be able to do most and for the price.
        Benchmarks and bits to follow, just to give an Idea, its not a Killer Speed Demon Unit
        Small Home Office, lots of uses, Heat No problem, No fan Noise.
        Should be able to find a Use for it easy.
          Now to have a look around Windows and some test on the
          WIndows Activated
          Hdd and network easy found on boot
          Device Manager Main Bits
          Hardware Info
          Crystal Mark, Little slow like most of the Budget Boxes be a better Beasty with Faster Ram I feel.
          CPU-Z
          Performance Test
          Aidia 64 bit of a peak then just a slow rise
          Cool Down
          More tinkering to be done,
          You get the Idea from the above its a Pretty Good and will just about most.
          Use the Box as Intended and to its capabilities and it will be fine and dandy
          Thanks to Gearbest for the chance to show and tell
          Gearbest
            More Tinkering on the Alfawise T1 Mini PC Gemini Lake N4100 Supports Windows 10 4GB + 64GB ROM 802.11/AC Gig lan
            Geekbench Compute:
            More Info: https://browser.geekbench.com/v4/compute/2901249
            Geekbench CPU
            More Info: https://browser.geekbench.com/v4/cpu/9861772
              Now for a look on the inside of the Alfawise T1 Mini PC Gemini Lake N4100 Supports Windows 10 4GB + 64GB ROM 802.11/AC Gig lan
              Remove the Base cover
              4 screws in the under the Pads, then work your way around the Join in will POP off.
              We have the RTC Battery, SATA port and not much else, Good looking PCB
              Out with the PCB, what a Good looking Heatsink that is
              You can see Antennae on LID, May take Both type of M2 Card (short and long) and lots and lots more, But the Heat sink can stay on this time
              WiFi Chip
              Ports Front
              Ports Rear
                Having a look around I found a longer M2 BM 380GB with the Double Notch, the M2 port is a Single Notch type so we should be good to go
                Fitted M2 has detected any luck maybe able to boot from it and install windows and Improve things a little
                I also tested the USB C port
                Plugging in a Doodocool DC30 Multi Port HDMI/USB/TFcard Hub...
                All worked except the HDMI port, since we have 2 HDMI ports its no loss, but might have been handy for that 3rd Monitor
